New Ls1 Owner Need's Help '''
I have a 2000 z28 ls1 that is basically stock. I just had a 4.10 gear installed and had the speedometer re calibrated. My problem is I noticed the car wants to when manually shifiting only, hold the rpm range and bang of the rev limiter until letting of the throttle then it will shif. I was told I need the rev limiter bumped and or the line pressure in the trans adjusted. Any help would be great. I really dont want to bang of the rev limiter when on the Nos. Thanks
He should change your shift points. You also have a trans that shifts electronicaly, the computer will shift at the optimal time. I burnt my trans up shifting it on my own.
