What LS3 style heads would you use?
Just getting opinions, but I figured I'd lay this out there. Which heads would you go with (Milled or unmilled) if you had the following setup:
Built L76,
stock cubes,
Callies Compstar LSC-1 3.625" crank,
6.125" Compstar H Beam connecting rods,
Wiseco 4.00" bore pistons with HD rings, (10.5:1 CR)
221/226, 567/564, 114 Lobe Sep cam,
ZR1 Head Gaskets,
Head studs,
1.7 YT Roller Rockers,
And Magnacharger of any displacement or equivalent roots style blower that you would have range from anywhere from 8-16 PSI.
(You also can have your choice of running any Shell, or Sonoco, or whatever fuel from 88-93 octane.)
Built L76,
stock cubes,
ZR1 Head Gaskets,
Head studs,
