M6 MSD 2step
Old 03-23-2011, 07:52 PM
bamaballa205's Avatar
Default M6 MSD 2step
Wanted to know which wires should I cut/splice on the clutch safety switch to install the MSD 8733 2step? The 2 wires going into the switch are purple/white and a solid green. I'm not worried about having to use the clutch to start the car.
Old 03-23-2011, 10:07 PM
Tally TransAm's Avatar
i bypassed my clutch safety switch and used it as a switched ground. no issues needing to press the clutch to start the car. i always check the shifter before i start the car anyways
Old 03-24-2011, 05:45 AM
Which wire did you end up using off of the Clutch switch? So basically cut/splice one wire and ground the other one?
Old 03-24-2011, 11:29 AM
SmokedOutZ28's Avatar
I used the clutch switch that controls the cruise control. Since it grounds to kill the cruise I just tapped in.
I believe it was the grey and blk wire on the white switch.
Old 03-24-2011, 02:05 PM
So doing it this way you still have your clutch safey switch to start the car along with using the clutch to activate the 2step?
Old 03-25-2011, 07:28 AM
Yes, no modifications to the clutch switch. Car still wont start without the clutch pressed in.
The switch in the middle and the harness on the left is what I have. Some cars may have the harness on the right.
Old 03-25-2011, 12:23 PM
Thanks man. Seems to be pretty simple
Quick Reply: M6 MSD 2step
