Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
found a simple cheap way to fill the transmission
Old 03-23-2011, 09:26 PM
VETTEX2's Avatar
Default found a simple cheap way to fill the transmission
http://www.amazon.com/Sprayco-Long-R.../dp/B000VYGCZW
works on an A4
I'm thinking it should work on a manual
I just used a heat gun to make the tube bend the way I needed it so it would fit.
I doubt it would work with 90wt but dexron flows easily and it worked to perfection
found one at a local hardware store for 4 bucks
FYI : the tube goes to the bottom so you just squeeze it to make it work
HOLDS 2 QTS.
Old 03-24-2011, 07:13 AM
pittman's Avatar
works on an A4
Cool, thx
Old 03-25-2011, 07:29 AM
C5natie's Avatar
Five bucks gets you a hand pump at Autozone. With your contraption there will always be a lot of fluid left behind in the bottle.
