How to service my 6 speed?
Old 03-24-2011, 10:45 PM
chasteen.1529's Avatar
Default How to service my 6 speed?
I'm new to manual transmissions. How do I change the fluid in my 99 z28 6 speed? Any suggest on best fluid to use? Can you use ATF in a manual?
Thanks for your help!
Old 03-24-2011, 11:02 PM
bigj2717's Avatar
There's a plug that says drain and a plug that says fill pretty simple. You need 4 qts of atf to fill it up
Old 03-25-2011, 12:41 AM
NVR_SPDS's Avatar
I think Mobil 1 ATF is pretty common fluid, whatever you do DO NOT use synthetic unless you either a) have a built trans, and thats what the builder recommends, or b) you want a built trans.
Old 03-25-2011, 04:01 PM
AdsoYo's Avatar
This write up will tell you everything you need to know step by step:
http://www.bfranker.badz28.com/fbody/lubeoil.htm
Old 03-25-2011, 07:09 PM
ncfastls1's Avatar
I thought Mobil 1 ATF was synthetic?? I just used generic carquest dex/merc (dexron III). But yea it's real simple. Just unscrew the drain plug and let it all drain out. Get a hand pump or something (can be bought from any parts store) and pump the fluid into the fill plug on the other side. Fill it up until it starts to run out the bottom of the fill hole.
Old 03-25-2011, 08:36 PM
F-BodyMind's Avatar
Pennzoil synchromesh seems to be popular for our trannys.
Quick Reply: How to service my 6 speed?
