General Maintenance & Repairs - precat 02 sensor needed?
View Full Version : precat 02 sensor needed?
johny
03-26-2011, 10:43 PM
i have a 97 v6 and i have an 02 sensors on each manifold and i have one more on the after the y pipe before the cat and one after the cat. is the one right before the cat needed or can i remove it to install my wide-band there. thanks.
wssix99
03-27-2011, 01:58 PM
All parts on a car are "needed." If you unplug the pre-cat sensor, you will be very disappointed...
johny
03-27-2011, 11:10 PM
i was thinking the 02 sensors on each manifold where controlling af ratio and the pre and post cat sensors monitored the catalytic to see if it was working. but if the pcm needs these readings that means i would have to install a bung. :( i don't care about a check engine light im getting a tune real soon but if the pcm needs these readings for air fuel ratio then ill keep it and install a bung.
Danny2tek
03-28-2011, 09:15 AM
you need the pre-cat O2, but can delete the post-cat (SES code for a bad cat)
bstuby
03-28-2011, 12:50 PM
Yes you need the precat the post cat just makes sure the cat is working properly as you stated
wssix99
03-28-2011, 04:34 PM
Right. You need that pre-cat for the fuel/air calculations.
The post-cat is not as dominant, but the factory service manual does state that it is used for some air/fuel calculations. So, if you can get away with deleting it given your state's emissions laws, you should probably make sure your PCM is happy with the delete method.
johny
03-30-2011, 10:44 PM
ok guys thanks, a bung is going on next week.
