Couple ls questions
Old 03-27-2011, 05:51 PM
Nate_67RS's Avatar
Default Couple ls questions
1) are there any mechanical differences other than displacement and iron block vs aluminum block that would make a true ls1-2 better than a 5.3 or 6.0.
2) If there isn't any difference then later on when i want more power if i want to swap from a 5.3 to 6.0 block other than intake and L92 heads everything from the original build should just swap over right?
I'm thinking if this is all correct starting with a 5.3 and after the car is finished and i'm ready to add alot of power switching up to the 6.0 block for my turbo setup.
I'll keep the 5.3 for a 280z i want to buy.
Old 03-27-2011, 06:09 PM
chuckd71's Avatar
Not sure I understand why you would purposely plan on doing things twice, but for most intents and purposes these motors are all the same in terms of what "fits" where.
Old 03-27-2011, 06:27 PM
Bo185's Avatar
The Gen III long blocks are all the same setup. All you will need to do is swap long blocks and retune the PCM.
Old 03-27-2011, 07:07 PM
Nate_67RS's Avatar
it all comes down to out of pocket at the moment if i go with a 5.3 and do most of the work now i have a running care now while i fix it up. Then when I am ready to spend on the engine again all i have to do is swap out the bigger block and add an FI system.
besides by then my son will be old enough to start his project and i will use the 5.3 as a base for a really nice 280z.
