Wiring harness plugs and cant find their home.
I'm installing my redone wiring harness and I have come up with a few problems, I cant find homes for the Cam Sensor plug, Oil pressure sensor plug, and a random map sensor on the passenger side of the wiring harness. I have pics of the plugs... I need to find their home... they look important.
The cam plugs at the back of the block if its a gen3 or at the front if its a gen4, are you sure you installed the sensor? Oil pressure plugs at the rear on all engines, make sure you installed the sender there also, and the map sensor is at the reat of the intake manifold.
