4l60 needs replaced in my 93 i think help?
sometimes it shifts great other times i take it out i pretty much have to manully go though the gears. will a normal 700r4 work or do i need a 4l60 for a 93? or does someone have an idea of whats going on?
LS1Tech Sponsor
You can adapt the 700r4 to replace that unit as its really just a 700r4 with a couple presure sensors added which when missing will not in fact set a code. You will have to change the round plug to a square one on the cars harness and make some changes in the internal trans wiring or not depending on where the trans comes from.
__________________
LS1Tech Sponsor
Well in our case we ship the units set up so its as simple as making sure there is power on PIN A and it will lockup anytime you get into 4th gear. But when your looking at stock replacements there are several different wiring variations so its hard to be more specific.
__________________
