Do i need the hobbs switch or not ?
as title say , i'm going to run duel intank but wondering about the wiring
actually the first pump will run with the factory harness ,For the 2nd pump, the harness leads out of the top of the assembly and is ready for a Hobbs switch , but my Question : i'll use N/A motor and some time spraying nos
is there any effect if these two pumps still run all the time ?
or should i go with hobbs switch to control my 2nd pump ?
need to see how you guys did the wiring for the same thing but only with N/A not Forced Induction
thanx
thanx
