TH350 no first gear!
Old 04-06-2011, 10:29 AM
89camaro's Avatar
Default TH350 no first gear!
i dont know anything about trannys and for some reason first gear slipps extermly bad! when my cars in first its almost like nutral it berly moves? but
2nd and 3rd gear are fine. what could be wrong?
Old 04-06-2011, 02:39 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
If it is slipping then it needs to be rebuilt, more than likely the clutches are bad
Old 04-06-2011, 05:15 PM
Predator T/A's Avatar
the loow roller clutch is most likely broken. the th350 shares this design with the 700r4/4l60e
Old 04-07-2011, 12:54 PM
89camaro's Avatar
tranny was just built not too long ago and reverse works fine too. so its just first gear
Quick Reply: TH350 no first gear!
