Rear mainshaft bearing t56
I need the rear main shaft bearing that goes behind the reverse gear for a t56 and the spacers that go on each side. This is the bearing that has the plastic cage on it an 12 rollers. Does any one know where to find this at? Thanks, Josh.
According to the parts listing you can get the bearing from ACDelco (S1314) or Tremec dealers (1386-134-001). The washers are Tremec 1386-193-009. They do come in the full rebuild kits from TGB, and you should be able to order them separately I would imagine.
OTOH, they don't usually wear, so you might find a T56 shop close by to you that has some decent take-outs that you can get for free/cheap...
