pcm swap
Thanks bmax
Ive read a few of them and they look pretty intimidating
Also read that it is not so much a straight swap. Havn't figured it all out yet
Do I just pick up any 99-00? Doesn't have to be auto etc?
Thanks
Thanks
Yes, 99 and up. Part number ends in 411.
If you have the software, You can flash what ever parameters you want, manual or auto, to the new PCM.
If you look around and read some more you will find you can do the things needed to your tune.
Just make small changes until you find what works for you.
Just takes time and patience, and lots of reading.
Good luck
Good luck
Fuel gauge will not work properly either. Get ahold of frost for a pcm if your planning on doing the swap. I have a 98 pcm if you decide to stay with a 98. It will need tuned though.
