what to set timing table? cam, heads,
Old 04-13-2011, 06:27 PM
pwrtrip75's Avatar
Default what to set timing table? cam, heads,
346ci, 224/224 .581/.581 112 cam, ported ls1 heads, in a C5 and a 6 speed. 93 octane now....
I know every engine will vary, but is there a general improved timing table to look at? I have the stock table in there now.
Old 04-14-2011, 06:14 AM
pwrtrip75's Avatar
Im not asking what curve to set it all at....like what should max full throttle timing be on average? I think factory its 28. what is too much? 36?
And what do people to their timing table when going from 93 octane to E85?
Old 04-14-2011, 11:53 AM
YellowToy/A's Avatar
28 is good 29 is max.
Old 04-15-2011, 07:54 AM
pwrtrip75's Avatar
Timing tables must be like big secrets or something.
Old 04-15-2011, 08:11 AM
LS1Tech Sponsor
Slowhawk's Avatar
Each car is different. Could be 20 degree's to 30 degree's.
Old 04-15-2011, 12:31 PM
Make the max timing areas under high load and RPM about 28. Smooth out any bucking at 1500 or so more or less timing. If you want to know what others have done look in the tune repository.
Quick Reply: what to set timing table? cam, heads,
