Ls7 tb
Old 04-13-2011, 07:37 PM
Shane1970's Avatar
Default Ls7 tb
will a LS7 90 mm TB fit on a LS3 intake and if it will is a $180.00 to much ? The LS7 has cable
Old 04-24-2011, 06:29 PM
KENS80V's Avatar
The LS3 and LS7 used the same throttle body.
LS2/LS7/LS3 throttle bodies up to 2008 were the same part number.
LS3/LS7 throttle bodies from 2009 and on are a different part number. They are most easily identified by the gold throttle blade. They can only be matched with ECMs from 2009 and newer.
Quick Reply: Ls7 tb
