Height difference between truck injectors (LQ9) and LS3 injectors?
Old 04-15-2011, 07:51 AM
dville_gt's Avatar
Default Height difference between truck injectors (LQ9) and LS3 injectors?
Right now I am running a modified truck rail (drilled/tapped on each end for -6 fittings) along with stock LQ9 injectors. All of this is on-top of a LS6 intake that I made custom hold-downs for.
I recently acquired a set of LS3 injectors and am wondering how much shorter they are then the LQ9 injectors. The LQ9 injectors I believe are shorter then the standard LS1/LS6 injectors, how much shorter are the LS3 injectors versus the LQ9?
Thanks in advance,
James
Old 04-15-2011, 11:16 AM
FICINJECTORS's Avatar
Thanks in advance,
James
the ls 3 injector is 38mm o ring to o ring. the lq9 is 48mm so you are missing 1/2 inch. We have these adapters. They even have a filter in them
http://www.corvetteinjectors.com/sho...?productid=366
Old 04-15-2011, 11:20 AM
dville_gt's Avatar
$9 per injector?
Old 04-15-2011, 11:38 AM
$9 per injector?
yes that is correct
Old 11-04-2011, 09:20 AM
Ford_Assassin's Avatar
10mm isn't quite .5".
10 x 0.0393= .0393"
Not sure how much a 10th of an inch would make though.
Quick Reply: Height difference between truck injectors (LQ9) and LS3 injectors?
