Which SVO Injectors for my Cam/Bolt-on LS1?
Old 04-19-2011, 12:48 PM
jc98ss's Avatar
Default Which SVO Injectors for my Cam/Bolt-on LS1?
The cam is in and it sounds great but it's still untuned......I talked to a tuner and he said that I might need to get Ford SVO "Red Top" injectors over my stock injectors so I don't run out of fuel in the higher RPM's......I responded saying that I'm not really interested in spinning the motor over 6000 due to the stock rod bolts and that my Camaro is basically just a street car, I only see the track about twice a year and that's just for ***** and giggles.....Can I get away with the stock injectors for under 6000rpm street driving, or do I really need to get a set of the Ford Red Tops.......If so, which ones?.....Do any of the sponsors carry them and are they difficult to change out?
Old 04-19-2011, 01:28 PM
jc98ss's Avatar
if i do need injectors, will these work?.....are these the red tops?......do they plug right into the factory harness?
http://sdparts.com/details/ford-raci...s/m-9593-b302f
Old 04-19-2011, 02:36 PM
jc98ss's Avatar
bumpp
Old 04-20-2011, 02:20 PM
jc98ss's Avatar
c'mon fellas, help me out
Old 04-20-2011, 02:47 PM
FICINJECTORS's Avatar
sent you a pm last night. The new style Bosch is a 36 in your car and will support your engine.
Old 04-20-2011, 09:36 PM
jc98ss's Avatar
thank you for the PM, but do i REALLY need these is what i'm asking?.....a product recommendation is fine and appreciated, but it doesn't answer any of my questions.
Quick Reply: Which SVO Injectors for my Cam/Bolt-on LS1?
