Do angled heater outlets exist?
Old 04-19-2011, 03:50 PM
Agent13's Avatar
Default Do angled heater outlets exist?
I'm doing the finishing touches on my LS3 swap and I'm wondering if anyone has angled heater outlets?
Here is a picture of my problem.
Old 04-19-2011, 03:55 PM
garys 68's Avatar
It turns out if you knock out the metal tubes the holes are the perfect size to NPT tap. A lot of C3 corvette conversions do this.
Old 04-19-2011, 03:56 PM
gofastwclass's Avatar
Gary's 68 has drilled and tapped the water outlets on his Corvette for that very reason. The only way I have seen or heard of what you need is by doing the same. I'm not aware of a standard water pump that has the ports relocated like you need.
**Look at the time stamps... hahahaha!!! Quick draw McGary!!!
Old 04-19-2011, 04:01 PM
Irish350's Avatar
might be able to press in new tubes, but i think tapping for a fitting is your best bet
Old 04-19-2011, 04:14 PM
RPD_Vette84's Avatar
i have seen angled heater hoses on some swaps
Old 04-19-2011, 04:23 PM
lizeec's Avatar
Default Heater
You can pull the original heater nipples out as they are a press fit and then tap the water pump with a 3/8 & 1/2 NPT tap then you will have a wide variety of angled heater hose nipples to choose from. Street & Performance sells some nifty ones that can be screwed in and can swivel in any direction that you like.
Old 04-20-2011, 05:28 PM
Tongboy's Avatar
all the big heater hose companies make the heater hoses in the standard dimensions in a big L shape - you get ~3" and then a nice 90 and then 12-48" of tube, trim down the short piece and you get a nice 90 degree rubber fitting without drilling/tapping or the expense of AN/NPT fittings. I used two sizes for the heater hoses that run to my heater box on the firewall for my swap.
Quick Reply: Do angled heater outlets exist?
