Way of telling if there is an aftermarket fuel pump?
I bought a ws6 recently. And im in the process of piecing together a procharger setup, And i know an upgraded fuel pump is needed. How ever i noticed there was a hot wire kit ran to the fuel pump, looks allot like the one that came with my racetronix kit a few years back on my old TA, Now is there a way to confirm its actually an upgraded pump? and someone didn't just run a hotwire kit to the pump? Without dropping the tank?
LS1TECH Sponsor
Chances are someone would not add a hot wire kit without replacing the pump.
Typically you will see approx 62# pressure at idle with an aftermarket 255, instead of 58#. I would start here. If you have higher idle pressure there is a good chance the pump was changed.
You you could check flow, but you would have to rig up a pressure regulator & fabricate some plumbing to do so. Free flow numbers are not sufficient.
thanks for the feed back. That was my thoughts exactly. i wouldn't think someone would just add a hot wire kit, I will be ordering a fuel pressure gauge soon anyhow, For when i put in my pro charger. So i can keep an eye on it. And ill check pressure then, Thanks agian
