Anyone use this for their clutch fluid?
Old 04-27-2011, 08:40 AM
flintwrench69's Avatar
Default Anyone use this for their clutch fluid?
Anyone ever use this in your clutch system?
http://www.tickperformance.com/produ...-1-liter-.html
Or this? Seems one of these brake fluids would hold up to heat better.
http://www.amazon.com/Motul-RBF600-S...=pd_sbs_auto_4
Old 04-27-2011, 08:52 AM
Kleeborp the Moderator™
MeentSS02's Avatar
I've used the Ate Super Blue, and I've even used Castrol SRF...both suffer from the same issue, and it isn't the fluid's fault - the seals in the slave fail to keep out clutch dust, which is what turns the fluid black and can cause high RPM shifting issues. I don't really use expensive fluid anymore, because it is more important that you keep the fluid in there fresh rather than fill it with the most expensive stuff known to man.
Old 04-27-2011, 09:51 AM
disc0monkey's Avatar
I went through the same thing trying different fluids like the ATE when I worked at a performance shop but if your suffering from issues of boiling temperature of the fluid it probably means you need to change out your fluid more. the prestone synthetic dot 4 is only a few degrees away from those expensive ones you listed. BUT if you dont change your fluid soon enough the boiling point drops drastically.
the most important thing is to pop a fresh bottle whenever you change your fluid. thats why those little prestone bottles are great and i dont think think that ATE one comes in little bottles
Old 04-28-2011, 07:51 AM
blue99fbody's Avatar
I run the motul and like it
Quick Reply: Anyone use this for their clutch fluid?
