Need Info on suspension
I do not know much about suspension. I have hotchiks SFC weld-ins already installed and i was wondering what would be best to install next. BMR LCA's will work with the SFCs right? I do not know if they attatch to the SFCs or are just really close to each other? Front and rear sway bars im definitely going with. Would a panhard rods be worth while? Help, Im clueless! Thanks.
not sure about the hotchiks SFC, but my BMR boxed SFC bolt to the LCA bracket in back and is welded up front. then i got the BMR LCA and they bolt up nice...they share the same bracket and bolt as the SFC. i did a BMR PHB at the same time as the LCA and it was a nice improvment...less flex, feals tighter. great upgrade.
Well any control arm from any company should work with your SFC's. I cant see any reason why they would not. I would def suggest aftermarket LCA's and a Panhard bar, you will notice a great difference with both installed.
