car wont run after th400 and 9 inch swap?
ok did a turbo 400 and 9 inch swap car was sitting for 2 monthes got everything done wen to start it had trouble starting then all the sudden it started right up then after about 10 seconds it shut right off started it up same thing then it would run for a few minutes then shut off it was doing it intermittanly does anyone know whats wrong?
Frans: Check your spark plugs/wires for spark.. Also, if it sat for a long time could have bad gas in there. If the tank is near empty, grab some new fuel and throw it in there, otherwise try to syphon out what you can and throw new gas in there.
- Matt
- Matt
- Matt
- Matt
yeah i checked spark and sometimes it gets it some times it doesnt and i dont think its fuel b/c it doesntr studder when it dies it just instantly dies
got EDIT? what tranny was in it to begin with? i don't know why, but, it may be looking for input from the old tranny. i am doing a 400 swap in about a month and will be disabling all of the old A4 parameters/tests.
