side skirt damage -gxp
Old 05-01-2011, 12:54 AM
gxp-miller-gxp's Avatar
Default side skirt damage -gxp
so before i got this car my mom owned it
well she drove through what she thought was a clump of snow on way to work ( ice block) and fucked **** up pretty good, messed up side skirt and put scratches on bottom side of car .
well the gxp side skirt is diffrent then the other ones because it comes up into to the fender while the other ones do not. well the flap that comes up is loose. if u look down the side skirt it self has a u shaped flang that looks as if it would grab on to a bolt then the car has a hole, what kind of screw do i need?
Old 05-01-2011, 08:47 AM
rvd9431's Avatar
shaped flange?? Look at the other side of your car, or post pics
Old 05-02-2011, 02:58 PM
lostnthenet's Avatar
I had a similar problem once. The side skirts use body clips. Check out these links.
The small clips are GM P/N#10323057 and they said I need 8 of them.
The large ones are GM P/N#10431761 and I need 5 of them.
I have found some decent prices online. For instance
http://www.clipsandfasteners.com/GM_...1_p/a19821.htm
and
http://cgi.ebay.com/ebaymotors/15-GM...mZ390036970379
Quick Reply: side skirt damage -gxp
