Need some wiring/ gauge help 98 firebird
Old 05-01-2011, 08:58 PM
Super Kaz's Avatar
Default Need some wiring/ gauge help 98 firebird
I bought my 98 firebird with the tach and fuel gauge inop. Thought the cluster was the problem so I sent it in and had it checked and rebuilt. Still don't work. Changed the level sensor when I upgraded the fuel pump, and still doesn't work. Checked the connector and harness by the tank also. Are broken wires common on these and where should I look? A little bit more info. I used a tech 2 and it can not read the fuel level sensor, but can read the rpms.
