Anyone with weld rts wheels, come inside
Rt-s
Weld RT-S wheels are Drilled / Designed to run 5/8" x 3" long studs with a standard through hole nut on the 5/8" dia. stud.
If you run 1/2" dia. studs or the standard metric studs...
You are supposed to run the 1/2" mag style or metric ( closed ) style nut with a 2" long stud. This is what weld told me on the phone.
+1 This
I am on factory OEM lugs with the shank style mag lugs and washers and they work just fine, plenty of thread. But I only got bolt ons so no extreme HP
Where is a good place to order the lugs with washer permanently attached? It's a bitch trying to keep the washers from spinning off the lug nut when you have the long stud + deep backspacing.
