Squealing noise from drivers side of engine bay
Old 05-02-2011, 09:00 PM
z28fernando's Avatar
Default Squealing noise from drivers side of engine bay
Hello, my car has developed a squealing noise from the driver's side of the engine bay, kind of sounds like a belt noise so i'm assuming it's the serpentine belt. So far everything is working normally on the car so where should I start as far as diagnosing the problem? I don't want the belt to snap on me lol. Thanks for the help.
Old 05-06-2011, 01:53 AM
346ci's Avatar
You can spray the belt (both sides) with brake clean while the car is running and if the squeal momentarily goes away, you have a noisy belt. If it keeps squealing try taking the belt off and spinning all your pulleys by hand and see if they make any noise or feel "rough".
Old 05-07-2011, 08:36 AM
BCKNBLK's Avatar
also take the belt off, by putting a 15mm i think wrench on the tensioner pulley and pry down to take it off then give yer tensioner wheels a spin to check the bearings,, they go sometimes too. I would assume its the belt tho.
Old 05-07-2011, 08:53 AM
sjsingle1's Avatar
pulley !!!
Old 05-08-2011, 10:25 PM
Thanks for the advice guys. I sprayed the hell out of the belt and it kept making noise so i'm assuming it's a pulley or something like that. How would I go about pulling the belt?
Old 05-08-2011, 10:34 PM
346ci's Avatar
As BCKNBLK said take a 15mm wrench or socket and push the tensioner down to relieve pressure on the belt.
Quick Reply: Squealing noise from drivers side of engine bay
