whats is this
whats is this
http://www.facebook.com/home.php#!/v...06529889369788
is this a bad valve????
if so can i put these heads on the stock motor...any supporting mods??? would it change my compression,could i get any hp/tq with them
http://nwga.craigslist.org/pts/2346366668.html
it is hard to tell on internet. where is the sound coming from? heads,block,etc? if you cant pin point it an old mechanic trick is to get a long screw driver, put diver side of screw driver to a point on motor and handle to your ear. you will be able to better pin point the sound this way. just move it around till you can tell close to where its at. and you will definitely but able to tell. it gets much loud when your in the right area.
probably not a good idea to rev it to much either.
how hard is it to replace a rod bearing.... would i be better off buying a lq4...would i make decent power with my mods any idea of what kind of power i would make
