any advice for trans. cooler install w/high cap. radiator?
I'm getting ready to install a B&M 24K supercooler and a TCI deep pan. Anyone have any recommendations for mounting the cooler, considering I already have SLP's high cap. radiator? Wasn't sure if that might cause space problems.
Here is a complete list of my perf. mods:
SLP SFCs, SLP STB, SLP reinforced Panhard Bar, SLP 85 mm MAF
installed at SLP's Toms River NJ site: 485 hp LS1 Cylinder Head & Cam (234/228) Package w/inst. kit including chrome molly pushrods 7.350" set of 16, double row nitrated timing chain, blueprinted oil pump LS1/LS6, off-road LT headers w/inst. kit, set of 2 high flow cats, LM exhaust mated to CME, K&N Air Filter, CAI, smooth bellows, moser 12-bolt 3.73 rear TCS & ABS 47 tooth w/inst. kit, torque converter 3300-3500, driveshaft loop, high capacity radiator, 160 deg. thermo. w/housing, painted reinforced LCA's, heavy duty adj. torque arm, dyno-based PCM4 tuning.
TIA.
edit: I drive an '02 Camaro SS.
TIA.
Last edited by gauSSian; 02-23-2004 at 11:18 AM. Reason: to add what model vehicle I am reffering to
Originally Posted by redls1z28
What kind of times are you running with your setup? The tranny cooler install is very easy, just take your time mounting it.
Not having a tranny cooler has kept me from the track. With spring coming up and the local fbody club getting ready to go to Gainesville Raceway, I want to be ready.
I'm just wondering where the best place to mount it would be given my mods.
