Drag Racing Tech
Drag Tires revisted.
Old 02-23-2004, 06:00 PM
Fast SS on TNT's Avatar
Default Drag Tires revisted.
My Welds are sold, along with my Hoosier Drag Slicks. My Bogarts should be here by the end of the week, so now I'm mulling over a DOT setup. The guy that I sold them to does not want the Hoosier slicks, and is facing the same decision.
What is the largest ET STREET/QTP Pro you can run, without beating the crap out of the fenderwells, and trimming? I was thinking about some Hoosier QTP's in a 27 X 11.5. I need a tall tire, due to running 4.10 gears and having a TH400. The demensions are only slightly smaller for contact patch, but I do lose 1 inch of diameter.
What to do???
Old 02-23-2004, 06:44 PM
EVIL's Avatar
27x11.5's you will run outta gear on a bigger shot. with the t56 in my car on the 27's with 4.10's my shift light was coming on before the end of the track trapping 132.
i have 28x13.5's now and i didnt have to do too much beating or cutting. took out the bump stop and hammered that in a little and then dented the front part of the inner fender. i need to trim the front part of the lower part of the fender/ground effects now to account for tire growth.
i dont think 27's will take you where you want to go....just my 2 cents.
Old 02-23-2004, 06:48 PM
Yeah, I have resigned myself to trimming. I sat down with the calculator, and even with a higher redline from the new heads and cam, I will be scraping the top of third.
Old 02-23-2004, 06:50 PM
EVIL's Avatar
i kinda cringed at the thought of it, but it wasnt too bad.
i have a th400 now with a 4000 stall and i couldnt imagine it on 27's, it would be squirley as hell!
Old 02-23-2004, 09:32 PM
I'm buying back the brand new Hoosiers on my Welds. I already did some fenderwell adjusting, but I will have to get a little more extensive for hard launches.
Luckily a local bought everything, and was never intending to keep the Hoosiers anyway.
Old 02-23-2004, 09:51 PM
The Bull
DERTY's Avatar
28 x 11.5 Hoosiers fit with minimal clearancing if the backspacing is good. Ran them on mine and they worked great. I can't say so much for the 28 x 10.5 Hoosier drags though. I thought they were crap.
