Does anyone have pics of a stock torque arm mounted?
Old 05-14-2011, 07:51 PM
cbra-klla's Avatar
Default Does anyone have pics of a stock torque arm mounted?
im putting a car back together thats been apart for a long time...apparently im missing part of the torque arm assembly that bolts to the tailshaft.. does anyone have pics or can explain exactly what im looking for
Old 05-14-2011, 08:23 PM
TransWS6Am's Avatar
maybe this?
Old 05-14-2011, 08:29 PM
cbra-klla's Avatar
ok i have than...but where does the end of the actual arm bolt to?? it has two hole in it im not seeing anything to bolt it to
Old 05-14-2011, 08:39 PM
jsteele90's Avatar
it slides into the bushing then the bushing gets slid into the mount and bolted down with one bolt
Old 05-14-2011, 09:44 PM
projectX's Avatar
Maybe someone has a write up on here?
Old 05-15-2011, 04:22 AM
TransWS6Am's Avatar
Doubtful, its a simple process installing the stock torque arm, you slide it into the bushing attached to the transmission housing, and then bolt it to the rear end with the 2 long bolts.
Old 05-15-2011, 10:50 AM
VIPRETR2's Avatar
I actually have the trans and TA out of one of my cars right now. I'll take a pic of it together and post it this evening if it will help you.
Here are the pics I took today, hope it helps.
http://i34.photobucket.com/albums/d1...rquearm010.jpg
http://i34.photobucket.com/albums/d1...rquearm008.jpg
http://i34.photobucket.com/albums/d1...rquearm006.jpg
http://i34.photobucket.com/albums/d1...rquearm004.jpg
http://i34.photobucket.com/albums/d1...rquearm001.jpg
