Help - Clutch/Transmission symptoms
Monster stage 3 clutch w/ billet flywheel.
Stock master & slave cylinders.
Symptoms are...
Gear shift gets rejected sometimes (esp. 3rd)
1st gear sometimes doesn't engage easily & pops out of gear.
Fast, short clutch shifts can result it grind noises though it goes into gear.
Sometimes there is lots of pressure to shift into gear (esp. 1st, 3rd, & reverse)
Kinda feels like its a 'dry' shift
Not enough clutch fluid?
Bubbles in system? Re-bleed & flush?
Throwout/pilot bearing bad?
Other ideas?
Symptoms are...
Other ideas?
