cleaning oil pickup tube
Old 05-21-2011, 03:31 PM
Zebisko's Avatar
Default cleaning oil pickup tube
I need to clean out my pickup tube, and wanted to know how to remove it, I can't seem to find anything about it anywhere.
Old 05-21-2011, 03:48 PM
nitrous2fast's Avatar
just pull it off the pump. well if its not been welded on.
Old 05-21-2011, 03:54 PM
RamAir95TA's Avatar
Clean it? It's not something that gets dirty unless you've dropped a roll of paper towels in the oil pan or something. What makes you think it needs to be "cleaned?" Or is the oil pan chock full of sludge?
Old 05-21-2011, 04:26 PM
shbox's Avatar
You could just take off the bottom plate of the pump and leave it attached if you really want to clean it. I don't ever use one that has been installed and removed from the pump. The interference fit will not be the same.
Old 05-21-2011, 05:35 PM
Zebisko's Avatar
Well, I had a valve spring where the inner spring broke a piece off and ripped the valve seal to shreds, sending all of that into the oil pan. Is welding a new one on the preferred method?
Old 05-21-2011, 06:22 PM
shbox's Avatar
A lot of people feel more confident with some sort of positive reinforcement of the pickup attachment.
Quick Reply: cleaning oil pickup tube
