EVAP/Purge Valve delete - what to plug the hole??
Old 05-28-2011, 11:59 PM
kendogg's Avatar
Default EVAP/Purge Valve delete - what to plug the hole??
I'm deleting EVAP on my swap (5.3l LM4, using stock truck intake manifold). I am deleting EVAP, and need to remove the purge valve for hood clearance. What are you guys using to plug that hole in the intake manifold?
Old 05-29-2011, 01:47 AM
71ANTICARB's Avatar
Check out what frojoe did.
https://ls1tech.com/forums/14940065-post470.html
Quick Reply: EVAP/Purge Valve delete - what to plug the hole??
