Those with Harlan Window switch & NX wet kit please chime in..
Hey guys i'm a bit confused regarding the harlan wiring. What i gather is i am supposed to ground it, put it to a switched 12v source and tap into the white in the PCm (i have an 02). Is that it? That doesn't quite make much sense to me, does it than have to be hooked up to the WOT switch from the PCM wire? Can someone please clarify this since i am not getting much response from Harlan. THank you.
