Did I just turn my Monster clutch disc into an expensive frisbee???
Old 05-29-2011, 09:58 PM
Dave-1970's Avatar
Default Did I just turn my Monster clutch disc into an expensive frisbee???
I've been having clutch disc (input shaft) alignment issues, and I believe my Monster Level 2 disc is slightly bent from pulling trans up with bolts and also running the engine for a few minutes with misaligned clutch/input shaft... So I set the disc on the pressure plate and noticed a 6-7'' area around the circumference of the disc that wasn't sitting flat on the pressure plate. I took feeler gauges to the area in question and came up with .008''... I'm thinking it's ruined...Do you Agree?? Anybody know how much Monster would charge for a replacement Level 2 disc??
Old 05-30-2011, 10:31 AM
Matt@SNLPerformance's Avatar
Give us a call and we can go over some thing with you.
817-750-2000
