Turbo LT1 guys turbo drain pics?
Old 06-01-2011, 11:21 PM
Chainsaw_Camaro's Avatar
Default Turbo LT1 guys turbo drain pics?
Please post pics of how and where you guys put your turbo oil drain. I am trying to figure out the best place on the pan to weld in the bung for the drain. Thanks.
Old 06-02-2011, 06:01 AM
lordrazo's Avatar
ok here is a pic of mine now the bottom one was from the previous owner and i knew it was too low and wrong angle at least for me so i welded a new -12an bung and then put alittle sealant around then painted heres a few pics
http://s704.photobucket.com/albums/w...t=DSCN0497.jpg
http://s704.photobucket.com/albums/w...t=DSCN0485.jpg
here is a pic on my old stock motor and pan
http://s704.photobucket.com/albums/w...DSCN0106-1.jpg
Old 06-02-2011, 10:30 AM
Thank you that does help. Has anybody put the drain farther back on the side of the pan? The kit I have came with a really nice anodized blue 90 fitting that I can only assume would go on the side of the pan.
Old 06-02-2011, 06:19 PM
kolorzcars's Avatar
i installed a ati procharger on a lt1 car and they had you puntch a hole in the front drivers corner, then tap the tappered hole with a pipe tap
Old 06-03-2011, 05:59 AM
lordrazo's Avatar
ya thats the same thing i did when i had a procharger as you can see in the last link with the stock pan bunched it and threaded it put a npt to barb fiting then jb welded it just in case lol that why with the new turbo and motor i wanted something nice and clean all an fittings
Quick Reply: Turbo LT1 guys turbo drain pics?
