24x guys come in, cam sensor/dowel question
So im in the middle of putting my engine back together and installed the efi 24x conversion, can't wait haha.
I have a couple questions about the cam sensor/clearance.
Here are 2 pictures and im wondering if i should be worried about the cam sensor picking up the dowel as a signal? I can get better pics if need be, or measurements even.
Thanks
Thanks
Wish i could help you but i installed a 24x system on my 89 l98 vett so i dident have to worry about that. If it was my car i think i would clearance it back as far as you could just in case. Did you try and get a hold of mike at efi connection yet about it? You will love the 24x system 4 sure once its done!
I ended up tapping it in a good eighth of a inch or so past the lowest point on the relucter. Should be fine i image, just wanted to make sure. thanks
