Hydraulic hose questions... Manual trans
Before goin to a cruise-in I met up with some friends. When I got in my car to leave I couldnt push my clutch pedal down. Yank the trans, clutch is destroyed. While the trans was out I wasnt able to push the clutch pedal all the way down. My friend got in and kicked it to the floor. When he did, the inner O-ring of the quick connect fitting popped halfway out. We pushed it back in and the plastic part with the hole was workin properly and the car was able to start (w/o the hose connected).
What does this white plastic part do (the inner plastic)?
How does the quick connect fitting work?
I had everything hooked up and runnin. Started to bleen the clutch and never got any pressure. I removed the master cylinder and when disconecting the fitting the hydraulic line broke. I am able to make a new line and can figure out a way to connect it all but will it work properly? will I have too much pressure or flow?
