ls7 with fbody accessories
Old 06-05-2011, 12:20 PM
gEtyOPaPiOn's Avatar
Default ls7 with fbody accessories
what balancer could be used to be aligned with the ls7 crankshaft and fbody accessories
Old 06-05-2011, 12:52 PM
litle88's Avatar
IIRCC and it's going on an fbody, than you must use the same accessories on the Ls7 from an Ls1. So either you can use an Ls1 u/d or stock Fbody crank pulley.
Old 06-07-2011, 08:48 AM
LS1TECH Sponsor
Katech_Jason's Avatar
We have a Katech spec ATI damper for LS7 with F-body accessories, but it is for no AC. If you don't have AC then it will work for you.
Old 06-07-2011, 10:49 PM
Needs to finish car
Chris442's Avatar
I've got an ATI balancer that is set up for F body accessories. The original one they had in the catalog didn't line up with the AC, so they had to build me a custom one. This was all about 4 years ago, though, so things could be different now. Bottom line is that it can be done.
Quick Reply: ls7 with fbody accessories
