Car has no electrical
Old 06-06-2011, 09:02 PM
keiichiZ28's Avatar
Default Car has no electrical
I seek the collective wisdom of the forums....
So my camaro has been sitting a couple of months. went to start it, nothing. No power locks etc so figure battery. Took it to autozone it tested fine. Replaced the screw post for the positive terminal still nothing. What am I missing? Car has just been parked in the driveway. What else should I be checking? Recap: no electrical no power locks no lights battery tested ok.
Old 06-07-2011, 08:23 AM
Save the manuals!
wssix99's Avatar
Check to make sure your battery cables are hooked up to the car.
If you get a tester and check the voltage between the positive terminal of the hooked up battery and the body of the car and then check the voltage at the starter, that should tell you a lot.
