Western Members CA, AZ, NV, UT, CO, NM, HI
need help taking ac unit out of 95z28?
Old 06-07-2011, 11:40 AM
CESARZ's Avatar
Default need help taking ac unit out of 95z28?
is it easy taking ac unit out of engine conpartment??????want it out..
Old 06-07-2011, 03:05 PM
ss.slp.ls1's Avatar
If you are referring to the AC compressor, it's not too difficult. However you will need a delete/bypass pulley in place of it to keep the use of a serpentine belt.
If you are referring to the AC/HVAC box that goes through the firewall, you will have to remove that from the inside of the car. There are several write-ups that have been posted, you'll have to search for them.
Old 06-08-2011, 11:03 AM
CESARZ's Avatar
ok thanks bro.will look into it
