spark plug wire not connecting to plug
Old 06-08-2011, 08:09 PM
Wimimc's Avatar
Default spark plug wire not connecting to plug
so i found out the one wire was loose. I've tried to reconnect but it wont accept it and i dont hear the click. The plug is tight, MSD plug wires btw. could it be a problem with the boot?
Old 06-08-2011, 08:27 PM
LS6427's Avatar
Make sure the end of the wire that snaps onto the tip of the plug has not collapsed. If it did, just stick an appropriately sized flat head screwdriver tip in it and widen it back open. I've had that happen before.
ALSO.....it may be opened up too large too. If so, crimp it closed so it will "click" onto the spark plug tip.
Old 06-09-2011, 04:41 PM
TCS OFF's Avatar
My MSD wires were F*cking tough to get onto the plugs from the box. I had to put dielectric grease on all the ends, and use a old plug to press in and out of the wire outside the car kinda to loosen them up till i could get them on easily enough. Definatly look inside the boot to see if the connector is too wide or screwed up in anyway
Old 06-09-2011, 05:43 PM
Wimimc's Avatar
it was too wide, so i crimped it a bit and sure enough it snapped on.
Do you think i should replace it anytime soon? i've had this intermittent pop/backfire when hiting the gas from a stop/slow roll. sometimes while cruising ~40-50 and i accelerate a little more it pops and studders. would this be the culprit?
