New regulator for use with the Aeromotive 340
Old 06-08-2011, 11:59 PM
01SOMZ28's Avatar
Default New regulator for use with the Aeromotive 340
Do i need to upgrade my stock regulator for use with the Aeromotive 340 pump? I was told the fuel psi will sky rocket.
Old 06-09-2011, 11:51 PM
sfd963's Avatar
Mine has done the.same.thing.with that set up. I have 90 psi. I'm getting a regulator for aero.
Old 06-10-2011, 05:38 PM
12sws27's Avatar
I don't have a ls1 but I do have a stock FPR and 340 and my pressure is fine.
Old 06-11-2011, 11:12 PM
fastsspr's Avatar
but the 340 means more volume no necessarily have to be more psi !
Old 06-14-2011, 01:26 PM
ShortChevy's Avatar
Yes, but pressure is only a restriction. Volume creates pressure. Overloading an undersized regulator with volume it can not handle will create extra pressure.
Old 06-17-2011, 12:21 AM
fastsspr's Avatar
make sense, how can you control that pressure?
deleting the factory regulator and using an aftermarket one?
Quick Reply: New regulator for use with the Aeromotive 340
