did I jack my oil pressure sensor....
Old 06-12-2011, 02:26 PM
BOA279's Avatar
Default did I jack my oil pressure sensor....
I've been doing a lot of work on the car and test drove it twice with no problem except it shakes really bad (poly motor mounts and trans mount). I just noticed today with the key out of the ignition that the oil pressure needle sits at 20psi. I've never seen that before. My daughter was sleeping so I didnt want to wake her but with power applied (key turned) it goes back to zero. I guess I will report back what I find after I start it tomorrow but what could cause it to sit at 20 with power off??
Old 06-12-2011, 02:41 PM
vetteboy99's Avatar
That's a good dad right there , usually some dads don't give a **** and will wake up there whole neighbor hood just for something like that.
Old 06-12-2011, 05:51 PM
_JB_'s Avatar
That is normal. If you press the trunk release you will see the gauge will go down each time. There has to be an electrical current for the gauge to move.
