Transmission Problems 99 Trans Am **VIDEO INSIDE**
for some reason it will not shift to 3rd. we tried manually shifting it but it would still not work... any ideas?
http://www.youtube.com/watch?v=nW0Z6abWZ7s
http://www.youtube.com/watch?v=3oVzX2ozxiU
LS1Tech Sponsor
Well if its does not neutral where 3rd should be I would have to think either the 2-3 shift valve is stuck or the 2-3 solenoid is. The only other possibilitie is the 3-4 clutch piston is completely blown out and venting the oil which would also cause only 1-2 as the 3-4 clutch oil is used to release the 2nd servo. This is all provided that the actual command for the 2-3 shift is actually being given.
__________________
