ugh, should I worry about this?
Old 06-19-2011, 08:16 PM
02v8ta's Avatar
Default ugh, should I worry about this?
Notice the "sealant" around the thermostat housing? Looks almost like silicone if silicone turns grayish in the elements? I was going to swap it out with a 160 but figured not to even bother with it yet. Hope the bitch doesn't leak when i do....
Old 06-19-2011, 08:20 PM
defaultexistence's Avatar
If t-stat is installed and fasteners torqued properly the new t-stat rubber seal wont need silicone... Clean all that crap off
Old 06-19-2011, 08:31 PM
Badazz 97 TA's Avatar
yeah it shouldnt need any at all. wonder why they did that. It was probably just the black rtv sealant
Old 06-19-2011, 08:41 PM
02v8ta's Avatar
Now i'm concerned someone did that Think i should be fine once replaced with the new one and the o ring?
Old 06-19-2011, 08:53 PM
RamAir95TA's Avatar
It's not going to hurt anything, calm down.
Just pull the old one out, clean up the silicone, then install the new one sans silicone.
Old 06-19-2011, 09:05 PM
02v8ta's Avatar
Thanks for the chill pill, haha
Old 06-20-2011, 01:04 AM
MasterTomos's Avatar
Btw new thermostats come with new o-rings IIRC
Old 06-20-2011, 03:41 AM
boostedlt1's Avatar
do the throttle body bypass while you're in there
Old 06-20-2011, 11:33 AM
02v8ta's Avatar
Not familiar with this. Feel like explaining or posting a link for reading?
Old 06-20-2011, 11:35 AM
Village Troll
SS RRR's Avatar
Let me Google that for you.
Old 06-20-2011, 01:37 PM
93M6Formula's Avatar
I had to use silicone around my water neck when I replaced the waterpump because when I filled up the coolant, it started seeping out even without pressure. I assume since it was an aftermarket pump that maybe the casting had imperfections or something.
Old 06-20-2011, 04:25 PM
Village Troll
SS RRR's Avatar
You are very likely correct. It's sad, but finding quality replacement parts for these engines is becoming a real problem. I replaced my radiator a few months ago with an Autozone special. Every single port, inlet/outlet was smaller than stock, meaning the stock hose clamps did not have enough force to keep coolant from seeping. I had to do some work on the tabs for the coolant level sensor as well has basically almost having to hammer it into place. Frustrating as hell.
Quick Reply: ugh, should I worry about this?
