Help me figure this out...
Old 06-20-2011, 07:25 PM
99LingenfelterSS's Avatar
Default Help me figure this out...
I just about a 93 camaro earlier today for a little of nothing because it was not running. I bring it home and decide to tinker with it to see if i can get it running. car would turn over but would not crank. I check the fuse box under the hood to find a 10 amp ignition fuse blown. The car blows every ten amp fuse i put in it. I put a 15 amp in it and nothing still. i put a 20 amp and a 30 amp fuse in its place and the car cranks and runs like a champ. The only problem is that the pcm wires are getting really hot on 20 and 30 amp fuses. Anyone have any idea what is going on here?
Old 06-22-2011, 01:51 PM
2001NBMZ28's Avatar
I'd look in the owners manual and find out what the corrrect size fuse is first, what else might be on that circuit, etc. Since it's a '93 you can also check for any codes by jumpering the DLC pins. Just a couple ideas.
Old 06-22-2011, 06:02 PM
Save the manuals!
wssix99's Avatar
Great advice. On my '99 the fuse is a 15A. Maybe someone with a '93 can check?
Old 06-22-2011, 10:14 PM
Elthesh's Avatar
Word of advice. Until you know the exact size fuse to put in there, upping the fuse size will do little more than get you a fried set of wires, and possibly a fried PCM. If it's a 10 amp fuse from the factory, it's 10 amps for a reason. You've got a wiring problem that's causing the fuses to blow. Fix the problem first.
