ok i gave in and went to a dealership to figure out my prob
ok well i went to a dealership to have my car diagnosed and i got absolutely nooooo where.. my car is throwing up a p0131, p0137, p0151, p0157 the only thing the told me was its my o2s reading low voltage... well no kiddding i knew that weeks ago... but they said i should replace them they showed me on there scanner that it was jumping slow and dropping to low 60s on the voltage or whatever.. but the thing is if the car is acctually leaning out ... wouldnt that drop the voltage on the scanner... i dono what to do to fix it.. this is making me crazy!!!!!!!!
i checked for vacuum leaks because how bad it stumbles and hesitates . couldn't find anything yet.. and my fuel system is 60 psi a few months back my friend put in some oe boshe o2 sensors.. and it was doing the same thing before he installed them...but before he changed them all out it was only reading one bad one ........so as of now i have tried these fallowing things...
Ok ..
I cleaned the mass air flow sensor
I checked fuel pressure 60 psi all the time
I ran injector cleanor threw it
I also deleted the pcv system.
Only mod is borla exaust
things i think it could possibly be
mass air flow messed up
spark plug wires
egr vac leak
maybe a short in the o2 sensors wires
o2 sensors
any other things you think might be able to fix this would be very appreciated...
Ok ..
spark plug wires
egr vac leak
o2 sensors
omg you guys are freaking genius !!!! i unplugged it and it ran like a freaking maniac and i tried to get the lean codes to pop back up and the only code that came up was the messed up mas air... omg im soooo freaking happy thank you so much..
so on another note... what kind of maf should i get and suggestions ?
A stock replacement. You can get them on here all day for 30-40$ shipped.
I don't recommend changing to a different maf unless you are going to retune for it. In that case a zo6 or truck maf is the best bang for the buck.
Post here before going to the dealer, that was obvious.. 95% of techs at them are a joke at best.
