TH350 swap??
TH350 swap??
An Idea ive been throwing around my grandpa has a TH350 built out of his Monte Carlo with a 3500 stall and everything. I see a lot of guys doing the TH400 swaps is there a reason people do that over the TH350?? I'm sure I will need a crossmember and drive shaft and things like that but was just curious why people don't build the TH350 over the TH400
(If it comes to this my car will be a tin can race car have the other 4L60E out of my parts car going into mine and hopefully it holds up)
I have a th350 and it does great. On high tq motors the trans brakes creep sometimes but all and al itsok. Make sure it has a hardend sprag ring thing and a 700r4 high element sprag. Also don't do second gear roll punches and it'll last forever.
If the tranny your getting has a 9" tailshaft you can use the same drive shaft, but you also can modify your stock cross member to, one bolt will work for the linkage. thats about all off the top of my head.
