Speaker/Amp Help
Speaker/Amp Help
First off I'm a Engine guy, and not a stereo guy . I purchased my '01 Z, and it came with tweeters, all the speakers, and no Sub. I traded the aftermarket amp in it for some other things, and now I need a new amp. What amp will work with tweeters, all the speakers, and 1 Sub?
Thanks.
Thanks.
A 5-channel amp will do the trick perfectly. I have several very good ones that I have used so many times I have lost count. The ones I use the most are from JL Audio, JBL, Infinity, Cadence, and Boston.
The JL amp though pricey ($449.99) is about the size of a sheet of standard paper...actually slightly smaller so it can be mounted in the area where the stock amp was or other tight spaces. Cool thing is it will run an entire system efficiently from 1 amp.
